Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: k-jet help
    sydney
    oh well so much for the 4 day convertion. Hopefully it will be finished soon.
    I have a 16v in a mk1 running k-jet with no knock sensor no vacum adv or electronic vac adv, no cold start, no power to the warm up reg, no isv valve and running a 4spd kept up door to door with an ss prob about 03 mod ute. The motor runs great, gearbox sounds a little worse for wear only been running on the motor for a few weeks.
    Only thing is that when i start it in the morn it sounds a little like a rotary
    wavering up and down until things warm up a little about a min of keeping the revs steady and she's right to go starts first time e t.
    and it's a pl pref motor with the smaller intake cam than the kr. also if you can get it on the dyno takes no time to adjust the mixture and the timing while it's on the rolling road wich will put your mind at peace and knowing that your not running it to lean as the 16v doesn't like it. or the other way round not running to rich as you will lose power also.
    sorry for the blab clad to hear of another 16v daily drver mk1
    cheers dave
    sydney
    i'm going to have to try and tune it right
    webbers are so much easier.
    Dec 2005
    Quote Originally Posted by DOHCDAVE
    running a 4spd
    cheers dave
    Someone give this man a 5 speed!
    Camden, Sydney
    Quote Originally Posted by worm
    running a 4spd
    cheers dave
    I did, he just needs to fit it.
    Golfwise Guest
    Will you give me one too
    sydney
    Ok boys she's starting to run quite well now and sounds very throaty.
    Thanks for all the helpfull advice. Now i need to pick your brains a bit more. I need the cold start set up explained to me, i have a harness for it but i would really like to know exactly how it works so i can hook it up effectively.
    Does the cold start injector stay on all the time until the warm up regulator turns it off or does it just turn on for a few seconds and stop
    And does the idle stablizer used or do i block it from running in to the large tube but let it vent down to where the injector is
    or do i just let it open whilst it is cranking only
    Any help or info in the system would be great
    Cheeers
    Camden, Sydney
    OK, the power going from the ign switch ( 50) to the starter solenoid (50) has a take off, going to the cold start valve, and in parallel to the thermo time switch. ( shown as red with black trace ), this allows power to warm up the thermo time switch bi metallic strip,
    The other side of the cold start valve goes to earth via the thermo time switch..ie when the time switch has sufficiently warmed up, then it breaks the earth flow for the cold start valve.. ( from memory something like 5 or 8 seconds..)
    Borrowed from an earlier post, thanks to roccodingo
