sounds like the switch at the back of the ignition barrel is broken.
about 30 bucks to replace (i did my mk2 a few months ago)
hey dubbers , this is the problem now !!!!
my mk1 wont start ?? when i turn the ignition i can not hear the fuel pump turn on (the buzzing noise) from near the air filter k-jectronic, i know i have a stuffed ignition coil as well but that wouldnt make a difference ! i did have a problem with the key ignition switch behind the barrel , but have to jiggle and hold down the back of it to try and start the engine !!!
i have checked all fuses ect .... any ideas ?
You can bridge the fuel pump relay with a piece of wire and 2 spade terminals.
Depending on the relay fitted it will prime when the ignition is turned on MK2 relay or when the ignition is turned off mk1 relay.
It will only run otherwise when the engine is rotating.
The buzzing near the air filter isn't the fuel pump. That could be something else like a solenoid valve.
Is this a built up car or factory GTI?
If you have a workshop manual with the diagram in, you could hot wire it to run it. I take it your don't drive it at the moment?
If it ran and the ignition switch seems to be the problem, buy one and just plug it onto the loom. Use a flat screwdriver to start the car.
THe coil sends a signal that the car is running to make the pump go.
