Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: k-jectronic fuel,problem
    Sep 2007
    perth western australia
    hey dubbers , this is the problem now !!!!
    my mk1 wont start ?? when i turn the ignition i can not hear the fuel pump turn on (the buzzing noise) from near the air filter k-jectronic, i know i have a stuffed ignition coil as well but that wouldnt make a difference ! i did have a problem with the key ignition switch behind the barrel , but have to jiggle and hold down the back of it to try and start the engine !!!
    i have checked all fuses ect .... any ideas ?
    sounds like the switch at the back of the ignition barrel is broken.
    about 30 bucks to replace (i did my mk2 a few months ago)
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
    Sep 2007
    Quote Originally Posted by velly_16v_cab View Post
    i see !! so would that stop the fuel pump as well ??
    You can bridge the fuel pump relay with a piece of wire and 2 spade terminals.
    Depending on the relay fitted it will prime when the ignition is turned on MK2 relay or when the ignition is turned off mk1 relay.
    It will only run otherwise when the engine is rotating.
    The buzzing near the air filter isn't the fuel pump. That could be something else like a solenoid valve.
    Is this a built up car or factory GTI?
    Sep 2007
    its a factory , it does seem it was a left hand drive at one point in america !! i do realize the fuel pump is on the right hand rear back , and it was priming before as normal , this car is getting to be a real problem it seems !
    If you have a workshop manual with the diagram in, you could hot wire it to run it. I take it your don't drive it at the moment?
    If it ran and the ignition switch seems to be the problem, buy one and just plug it onto the loom. Use a flat screwdriver to start the car.
    Sep 2007
    well yes have been driving it for the last few weeks , lol if i start cutting wires and stuff it will go wrong , just cant get it with electronics, too much wire in there , and i wouldnt even no which one is the immobiliser , going to ditch that thing !!
    Camden, Sydney
    THe coil sends a signal that the car is running to make the pump go.
    Sep 2007
    ahhh ok that explains that !!!! so im going to need a new coil , as it has burnt out inside where the middle distributer plug goes ( well its all corroded) on the search for one of them now !!!
    Quote Originally Posted by dubsweeper View Post
    I meant to jump the connector with wires not to chop it all about.
    The coil being bad wouldn't stop the pump working if it was still in circuit. It just wouldn't fire. The pump would run when you cranked the motor.
