Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 78
Thread: Its been a while...........
  1. #41
    really looking great Andrew! dam neat
  2. #42
    Mar 2007
    South Brisbane
  3. #43
    dam son! Really getting stuck into it Looks awesome
  4. #44
    sydney
    Shooot merry trucker Christmas to you.
    I would have gotten wood from the picture message you sent me.. But I was sniffing Nitro, so i already had it. Hahaha.
  5. #45
    Jun 2007
    Eastern Suburbs Melbourne
    NAISE!!!
    keep it up.
    i like volkswagens
  6. #46
    Mar 2007
    South Brisbane
    Thanks guys, its overwhelming how much still needs to be done hahaha, but it is getting there I do all the work myself so its a long process .
    Does anyone have a wiring diagram for a 3 wire vw alternator???
    oil cooler mounted.
  7. #47
    sydney
    Does this help??
    Alternator being C
    Battery A
    Starter B
    Coil N
  8. #48
    Mar 2007
    South Brisbane
    It does do you have a better quality image?
    Undercarriage..........
  9. #49
    Gosford Central Coast NSW
    Wow, great stuff mate!
    Which alt do you have? - anyway they are basically all the same - the later ones have a b+ for the charge light and a w for tach signal on some cars. both are pretty safe i.e if you wire up the w to the charge light you wont cause any problems. You wont need the w terminal cos you'll get tach signal from the ignition.
    So basically all you need is to connect the big terminal to the battery +, earth the alt body well and one of the little plugs goes to the charge light circuit on the dash.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  10. #50
    Mar 2007
    South Brisbane
    Thanks gldgti, makes sense to me now i wired it up a couple years ago just needed my memory refreshed Ive basically binned the stock wiring loom and opted for a universal hotrod wiring loom and fuse box less complicated Ill post pix as i start the wiring in the mean time fitted the front brakes.
