really looking great Andrew!dam neat
dam son! Really getting stuck into itLooks awesome
NAISE!!!
keep it up.
Thanks guys, its overwhelming how much still needs to be done hahaha, but it is getting thereI do all the work myself so its a long process .
Does anyone have a wiring diagram for a 3 wire vw alternator???
oil cooler mounted.
It does do you have a better quality image?
Undercarriage..........
Wow, great stuff mate!
Which alt do you have? - anyway they are basically all the same - the later ones have a b+ for the charge light and a w for tach signal on some cars. both are pretty safe i.e if you wire up the w to the charge light you wont cause any problems. You wont need the w terminal cos you'll get tach signal from the ignition.
So basically all you need is to connect the big terminal to the battery +, earth the alt body well and one of the little plugs goes to the charge light circuit on the dash.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
Thanks gldgti, makes sense to me now i wired it up a couple years ago just needed my memory refreshed Ive basically binned the stock wiring loom and opted for a universal hotrod wiring loom and fuse box less complicatedIll post pix as i start the wiring in the mean time fitted the front brakes.
