H&R do stud conversion kits from memory
Hey guys, i was curious, rather than using the european style and using bolts/studs, is there a way to put in bolts on the hub, so that you can use a nut instead. Kinda of like a honda?
For exmple, for people using spacers, they need to have longer bolts, however what if a bolt was put in and inverted into the hub, that way spacers could be used, and you could use nuts instead. Which would make it a hell of alot easier to put a wheel on LOL.
I assume its easy for the drums brakes, but what about discs? I hope im making sense.. hahah
Any advice would help.
- Brown U.S import 81 cabby
- 88 Honda crx b18cr
Lots of companies make studs for Mk1. Do a bit more research before you decide.
ARP-bolts.com | The Official Site of Automotive Racing Products, Inc.
M12x1.5 Performance Studs
ISA-Racing Online Shop - Radbolzen und -muttern
Wheel Studs | Rallynuts
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
Pete i assume, you screw in those studs, where the bolts would originally go, however inverted? I heard bursons might be able to stock them too..
Yes, some types screw in from the front. The AIT one are the way to go if you choose that option.
For motor sport I plan on using ones that press in from the rear.
7? MK1 Caddy
12 Amarok
We used studs that pressed in on the Blue Flog. Initially disc/drum and now disc/disc. You can get them in different lengths and makes changing a flat in the middle of the forrest a lot easier
I'm not sure how rego go about approving this but on my Polo I fitted high tensile bolts from a hardware store. Bolted in from the back and loctited in. They are a standard metric thread, from memory I think they were 12 mm but don't quote me. The store even had them in different lengths. Just remember to spin the disk/drum around a few times to make sure the head of the bolt doesn't catch on anything. I think the bolts cost around $1.50 each.
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
