Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Intro
    Allens Rivulet, Tasmania
    baskerville run next sunday eh?? well that sucks, as my car cant make the trip, for many reasons someone wanna give me a ride hehe
    TassieGTi Guest
    YEAH...Club Day at Baskerville next Sunday! Hoping to have Silver car up and running for a few laps!
    DOH! i want my car to be running
    wolfsburg Guest
    500 car club have the 7th down as Baskerville on their site run by HSCC. Is this the same as mentioned?
    VanKronenburg Guest
    Quote Originally Posted by gotrice
    If you want brakes then go for the GTI MK2 disks and rotors. They bolt straight up and are cheap. Brian from GTI imports can sort you out.
    Are you talking the 256mm brakes? They aren't a direct swap (this is common misinformation!!). You need a setup from the following cars for it to be a direct swap:
    audi 80 quatro (83-85)
    audi 90 5 cylinder (85-87)
    audi caupe 5 cylinder (85-8
    double check the bolt hole spacings (10mm holes spaced at 76mm not 12mm spaced at 96mm).
    You are best to install a proper 22mm master cylinder and servo at the same time.
    The braking with this setup is good, but I prefer a 280mm upgrade with rear disc brakes which is still cheap if using VW parts.
    TassieGTi Guest
    That is correct! We are lucky! There is one out at Baskerville tomorrow and again next Sunday (Mini Car Club). Provided you have a basic CAMS license, $85 gets you a great days entertainment! Morning qualifying followed by 4 lap sprints with 3 other cars of similar lap times!
    sounds like a good day
    Golfwise Guest
    Gotrice.
    Mk2 discs and rotors eh!
    I know where to put the discs but what do I do with the rotors,where do they bolt on.
    Don't give advice if its not correct someone might believe you.
    Camden, Sydney
    Yeah wise words GolfWise.
    Mk1 GTI or early Audi 80 are better than stock Mk1s and will bolt straight on. You need Mk2 hubs and carriers for Mk2 brakes.
    What car do you have gotrice?
