Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Intake bolt drama's
    Jun 2011
    Sydney NSW
    Quote Originally Posted by Petska84 View Post
    Well i can officially say the intake is now off
    But I'm not proud of how I managed to get it off, I tried all of the above and still didn't come off. What was supposed to be my last resort didn't work, yes tried to cut the bolt off with the dremill drill but the motor burnt out sooooooooooo I went into the shed and got the good old sledge out. Stood on the scuttle panel and two whacks it was off
    So I guess we could add that to the list.
    Hope you have not done something to the head that you cannot see. Sometimes you do have to resort to the Irish spanner, but the trick is knowing how hard to hit AND where to hit
    Jan 2012
    St Albans, Victoria
    Quote Originally Posted by wai View Post
    Head seems to be fine.
    Jan 2012
    St Albans, Victoria
    How do people usually plug the injector holes when there going from injection to carby????
    Jan 2010
    Melb Westsideeeee
    I gotta swing past Peter, check it out
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
    Boronia VIC
    On Josh's car we unscrewed the injector holders and dropped coins in there with a bit of silastic and screwed the injector holders back down.
    I think 5c pieces were the right size, maybe10c.
    On one of my heads I left some old injectors in there and sealed up the fuel line connection on the injector.
    Some companies that sell carby kits sell dummy injectors to block off the ports.
    Another head I have has had the ports filled with epoxy metal.
    I've seen them welded up too.
    Another way that works really well is to use gearbox drain plugs, they screw straight in in place of the injector holders. The kind with the 17mm hex.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Jan 2012
    St Albans, Victoria
    Cool, thanks Pete I'll give it a go.
    Jan 2012
    St Albans, Victoria
    Quote Originally Posted by GeorgeMK1 View Post
    Yep you do George, I'll be around tonight and tomorrow, back to work on Sunday.
    Jul 2005
    Or you could just leave the injectors in if they are still around
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
    Jan 2012
    St Albans, Victoria
    I dropped by the nut and bolt shop today and picked up plugs that screwed straight in with a hex head, works a treat
