i think they are a 12mm thread with a 1.25 pitch?? and 40mm long with a 17mm head.. not 100% sure!
what are the wheel nut specs for a mk1? just going to grab some longer bolts while i'm at work, but dont have one to compare against. it'll save me having to make a special trip on the weekend.![]()
12x1.5
dom
VAGCAT to the rescue!
2 ---------
no longer available / for wheel disc 'steel'
M12X1,5X20 /
Pete
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
WHEEL BOLTS 12x1.5 40mm long thread - eBay Tyre Accessories, Wheels, Tyres, Car Parts, Accessories, Cars, Bikes, Boats. (end time 04-May-10 15:34:26 AEST)
that looks promising. may be a little too long. but that can be fixed.
Just be careful when going to longer wheel bolts
Too long & they can poke through into the rear drum & tear up the rear brake shoe assembly's.
I've had this happen to me before.
Fronts will be fine with longer bolts
BMW wheel bolts are a good size with only a fraction shaved off the ends.
They also come with a crazy hard black coating & look good too.
BMW and AUDI bolts can be found in good lengths. Pretty cheap at the self serve wreckers too.
Pete
7? MK1 Caddy
12 Amarok
i managed to order longer wheel nuts through my work (from NICE products) There are two different types of wheel studs (as far as i know) and the ones that i got are the same length as the longer ones that come stock on a golf. i can probably dig up a part number.
how much longer though? i need rears 15mm longer and and fronts 8mm longer...
how much longer are the beemer ones?
