Results 1 to 10 of 13
Thread: 1.1 southafrican to 1.6lt conversion
    Feb 2010
    perth, western australia
    hey guys.
    so i have a 1.1 southafrican import and was wondering if anyone knows how hard it will be for me to fit a 1.6lt motor and gearbox into it.
    i ahve been told that it can't be done easily.
    Nov 2005
    hey mate
    yes thats true, its because the 1.1lt motors have a different engine mount position on one of the chassis legs, ill try dig up some comparison pics to show you, BUT, it can be done by picking the welds of the engine mount and welding in the 1.6-1.8 engine mount where it should go
    edit: the green one is from a 1.1-1.3 block you can see the engine mount sits ontop of the chassis leg on the left of screen, this is like yours
    NOW this pic is of a 1.6-1.8 engine block you can see on the same side the engine mount is missing and is located under the chassis leg
    cheers
    dom
    Camden, Sydney
    The mounting point weded to the chassis on the drivers side rail needs to be ground off and a 1.6-1.8 one welded on in the correct spot.
    All rest will bolt in.
    Jan 2010
    Melb Westsideeeee
    Dunno mate, when i was in s.a my old man changed a 1.3 to a 1.8 with box too. I dont know how much differnt the 1.3 and 1.1 are though.
    Good luck with it.
    Camden, Sydney
    1.1 and 1.3 are the smallblock Mk1 engines and lean back, hence the mounting point.
    The 1.6, 1.8 and 2L are the big block ones and lean forward, so have the other mounting position.
    Feb 2010
    cool thanks heaps. i wondered if that was the case. what about the gear boxes themselves does anyone know if they are the same? i got a yellow sticker and i dont have first gear so i need to put a new box into it. i figured might as well put a new motor in while i am there haha. but if the boxes are the same i might just do that for now and get the engine sorted later.
    Perth. WA
    Make sure the gearshift is adjusted correctly before you go ripping boxes out... As for the engine and box I am stripping a perky 1.6 in a few weeks, come have a test drive if ya want. will save you the rhs engine frame mount.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Dec 2008
    Perth
    Just a question on this, Will caleb be able to use his same steering rack and linkages with the 1.6 engine?
