Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Instrument Cluster
    Oakleigh VIC
    screws? there are screws that are meant to hold the cluster in??
    Yep that black steel clip just to the right of where you drew the 2 should have a self tapper in it. Don't bother putting one in there though it's a PITA to get out.
    Pete
    Jun 2007
    Eastern Suburbs Melbourne
    Pete
    Oh yea, I see it. meh. Due to the dash being warped like it is, the cluster is naturally, well, 'stuck' in
    did a quick search for the 'pinouts', came up empty handed.
    So does anyone know which is whic (earth, +12V, +7V reg, with 1,2,3) or do I just need to make a circuit and test it with a multi?
    i like volkswagens
    Feb 2007
    Eastern Melbourne, VIC
    hahhah Not on mine!
    LOL, I can remove mine in about 30 sec, had to do it too many times already! Playing with electrics sucks, I feel your pain
    The Baltic Bruiser™
    Oakleigh VIC
    Josh asked the same question about the regulator in 2005, you guys need to talk more
    http://www.vwwatercooled.org.au/newf...ight=regulator
    I'll have a look at one of my stuffed clusters and work out the pin out for you If I can't see it online anywhere.
    Pete
    Oakleigh VIC
    I knew I'd seen it here somewhere.
    http://www.vwwatercooled.org.au/newf...hlight=voltage
    top - 12V constant
    middle - Earth
    bottom - power supply/charging voltage
    Pete
    Jun 2007
    gah! thanks Pete. Really appreaciate it!
    I even saw that post, in the thread started by Cam, the former owner of my car! and even saw that bit in there, just didn't click!
    OT: you know those bolts I lost. well I found them put them in a box and everything, in what turned out to be a really obvious (but not visible) spot. So I went and used most of the nuts and stuff that you gave me Pete, why not? All the exhaust manifold bolts were starting to get rounded off anyways! Thanks again Pete.
    i like volkswagens
