Early cars ran the fuel line up the inside of the wheel well then thru that hole. patch it ..
Does anyone know if this can be filled in?
I have a little surface rust around this opening and wish to cut out and replace with fresh steel.
I don't know if it may be used to gain access for locking the timing gears if changing timing belt?
Lots of MK 1 Scirocco's...
Cheers,
Grant...
Thanks Grant.
Interesting stuff!
I'll go ahead and fill it in.
Can't help with my fuel expansion tank question can you?
Thanks
Martin
