Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Inlet manifold still not coming off!
    the inlet manifold is still not coming offf. i have taken out all bolts out and given it a healthy whack with a block of wood and a sledge hammer (yes i was being careful).... nothing. help????!!!!!
    wolfsburg Guest
    I know you tried a block of wood and sledge hammer, I would try a rubber mallet if you have one. A constant tapping while wiggling may be what it requires?
    Do you have any movement at all?
    imported_brackie Guest
    Stress or strain??
    From my experience you need to apply pressure to the off-side of anything that you are trying to separate. Doesn't matter if it's a ball joint, track rod end or cylinder head it needs to be levered away from the component with the greater mass before applying a shock. So in the case of your manifold (which I haven't seen and am only imagining) put a lever between it an the block/head/immovable object and then hit with a fibre/wooden/rubber mallet to dislodge. But, before you do anything more, check and double-check that there isn't something that you've missed still holding it on. I've done it a million times and cursed myself blue the same number.
    Jul 2005
    Of course the little flat bracket from the inlet manifold to the exhaust manifold is undone.
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
    Camden, Sydney
    Yeah if you are certain its undone. A scissor jack could be the go.
    i see no bracket?!
    absolutely no movement and no rubber mallet in site... someone suggested gasket remover>?
    Camden, Sydney
    one bolt in the bottom of the inlet manifold with a flat bracket between it and a bolt in the top of the exhaust manifold.
    its usually rusted. just undo it till the bolts snap then leave it off. 12 or 13mm spanner.
    Belgianwaffler Guest
    you did remove the bolt and bracket attached to the exhaust manifold right ?
    there aint no bracket there mate i mustve taken it off
    syncro Guest
    How about you count the bolts that have been removed and someone on the forum can tell you if that is all. Just to make sure
Similar Threads
  1. Phenolic manifold spacers
    By ibeezer in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 05-03-2007, 11:20 AM
  2. getting inlet manifold off the block
    By GoLfMan in forum Mk1 Golf
    Last Post: 15-08-2005, 10:15 PM
  3. How do you get the inlet manifold off
    Last Post: 23-07-2005, 08:58 PM
