Results 1 to 10 of 12
Thread: increasing power to the horn?
    Nov 2007
    I picked up a dual horn from a Seat Cordoba, i think, a while ago and I've put it in but it doesn't always work properly. I know they work, because when i connect them straight to the battery they work fine. Is there a way to increase the power that is going to the horn?
    Boronia VIC
    A relay should do the trick.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Mar 2008
    N/A
    Ahhhoooooooooooooooogah!
    Nov 2007
    would i be asking to much for you to just make a small diagram showing me how to wire it up?
    I'm not all that great when i comes to relays.
    You don't need a PhD degree in physic to understand how to wire up a relay.
    Relay # 30 -> battery +ve
    Relay # 85 -> ground
    Cut your horn +ve and wire it to Relay # 86
    Relay # 87 -> horn +ve input
    FAQ: RELAYS; how they work and how to wire it up...
    Boronia VIC
    Yeah, plenty of pics already on line.
    I'd just connect the two wires that run to your stock horn and connect them to the realy coil on 85 and 86.
    30 goes to battery.
    87 goes to one side of the horn. Earth the other side of the horn.
    There's a couple of different ways to do it.
    ANother issue can be the contacts behind the steering wheel. You might need a new switch or contact ring.
    7? MK1 Caddy
    12 Amarok
    Nov 2007
    thanks for your help guys. i wired it up like you said pete and she works a treat.
    Jul 2005
    Newcastle, NSW
    On the topic of relays, has anyone added a relay to the wiper motor with any success?
    Nov 2006
    Canberra, Australia
    Quote Originally Posted by mikinoz View Post
    If not, is there a way to make it rain slower?
    MY10 S3 3dr
    Nov 2010
    Burpengary, Queensland
    You can get nasal spray for this sort of problem
