The original MK1 fan and radiator is very outdated. Unless you're restoring it to "as new" from the factory I suggest replacing with something a lot more modern.
I'm running a radiator from a 91 Holden Barina which fits nicely under the slam panel, not in front of it and gives more clearance to fit things between the radiator and engine. Barina radiators are larger (wider) and a lot cheaper than old Golf ones too.
Any good sized fan and shroud from an aftermarket supplier like Supercheap or Repco will suit.
Paul
