Welcome to Mk1 ownership mate!
Suddenly speedo died, always at 0 km. The closest speedo related issue that I can searched is here http://www.vwwatercooled.org.au/newf...ghlight=speedo
Should I pull out the cable first or tracing electrical fault, don't know what happened to the cluster lately, many thing started to playing up
Parts for sale http://www.vwwatercooled.com.au/foru...ff-102387.html
if you've got a few other issues (electrical} I'd check all the earth points first, before I started pulling things apart.
Unless the speedo cable has just fallen out??
The earth wont cause this problem. Got to be the cable. Easy to remove and check!!
i agree, i would think it is the speedo cable, broken or worn, i think it goes to the gearbox...
No trade secret my friend. Just a very gentle juggle and pull out. If there is any resistance then you have a chance of losing it. By gently jiggling and a gentle pull you shouldnt have any probs. I have been working on golfs since 76 and I havent lost one yet. Patience does it. By unscrewing the nut on the cable behind the speedo you should be able to find if its broken I think.
If you can turn the inner cable or pull it out then its snapped!
I recently bought 10 new cables but they are all incorrect.
I am sure we all have secondhand ones lying around, hey!! I even have a short LHD one here now!!!
Andrew
matey that was my post one my old mk1.
What I found out that happened was that i fried both the speedo's. turned out it was some kind of electrical problem. memory isnt to crash hot but im sur eit was something to do with the earth, or the fusebox to some extend.
ahh the memories of owning several mk1's hahaha
2000 SAAB 9-5 Aero - Stage 2. 275hp 420Nm, Brew City Boost
1986 SAAB 900 Turbo 16 S
