Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Ignition lock
    Perth. WA
    the bentley shows you where to drill a 3 mm hole to release the spring plate that holds the barrel into the housing. then change the barrel. not much more expoensive to buy a complete head unit with a new bearing and barrel already fitted, if you cant be bothered with the hole drilling excersise.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Dec 2007
    Somewhere in Melbourne, Victoria
    Alas this is the price for owning a classic car like the Mk1 golf.
    Had the same problem with the same symptoms (eg: key in the right angle will activate the lock.)
    The issue is resolved best with a barrel replacement, while you are there an ignition switch replacement might not go astray, while it is all in pieces. Set aside some reasonable time to do the job.
    Best of luck
    1991 Golf GTI Manual - Tornado Red (Little Red Wagen)
    1998 Golf Cabriolet Manual - Black Magic Pearl (aka Rommel's Panzer) Deceased/written off
    1993 Golf Cabriolet Manual - Alpine White (aka Hitler Youth Wagen) Deceased/written off
    1976 Golf LS Manual - Bronco Brown (aka Roadrunner) Deceased/worn out
    Jan 2008
    Surrey Hills, Melbourne
    Thanks for that. I guess ignition switches are to be found on ebay too? I guess if I'm in there it would pay to replace anything potentially worn out. But I'm not sure if/when I might do it - a time consuming job and I don't have any off street parking and I'm not too mechanically inclined. There's always my Dad, but I'm not sure he's too keen.
    Jan 2008
    Does anyone know if a MK2 GTi ignition barrel would fit my Mk 1 ('76)?
    Jan 2008
    Quote Originally Posted by greasykitchen View Post
    Anyone?
    From what I can see, it depend's on what year the mk2 is.
    If it's upto & incl. 87 yes you can.
    They changed the part # of the barrel in the 87/88 cross over but the lock assembly still has the same part # through mk2 along with the ignition switch, so the year's may not matter at all.
