look for any screw or nut or anything coming off the throttle cable, follow it through from the accelerator pedal if you have to...
then tension it, more tension on it will open the throttle more and bring up the revs.
But no really, I like to look distinguished when I step out of the car. People are like, "wonder what he does for living."
I just reply, "your daughter, sir." - some dude on stanceworks
I had fixed half the broken crap but that just meant it was still halfway inoperable
With the engine turned off have someone press down a few times slightly on the accelerator pedal while you look at what moves on the carby. There should be a screw that holds the throttle open. The more you turn the screw the more the throttle opens. Set it so the car idles.
Paul
