mk1 golf lock set | eBay
You'll be ok as long as you can access the inside. You need to drill the ignition lock to replace the barrel, there's a little release pin in the lock housing. The boot lock is a bit different but you can make that work too.
I'll tell you over the email/phone how if you want.
