Results 1 to 10 of 16
Thread: how to undo a drive shaft nut?
    Apr 2006
    Melbourne, Victoria
    Hello,
    I have a set of hub assemblies with the outer CV joints but no drive shafts so there isnt much to stop the shaft from turning when i try to undo the drive shaft nut.
    Any suggestions???
    Cheers!
    Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
    White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
    Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
    Jun 2007
    Eastern Suburbs Melbourne
    Get a big adjustable wrench to hold onto the outer CV (from the rear) and then support it/postition it so it doesn't move whislt you get your 30mm socket with a really long torque arm to undo the nut.
    naturally, WD40, heat, rattle gun may also be of assistance.
    i like volkswagens
    Quote Originally Posted by hiho View Post
    Hello,
    Any suggestions???
    Cheers!
    if you have access to a vice, rattle gun and lots of WD40 you might have one solution
    otherwise, again stick it in a vice (with a rag wrapped around it of course!) and get stuck in with a torque bar
    hope this helps?
    Apr 2006
    Melbourne, Victoria
    i just realised that i can bolt a wheel to the hub! that should give me a bit more to hold onto!
    Sep 2007
    that also works.
    alternatively, you can get someone to jump in the car and squish the brake pedal as you stand on a 2m steel pipe.
    87' MK2 GTI
    13' MK7 TDI
    Jan 2009
    south west sydney
    i tried about a 2m pipe and still would not budge untill i had some on put their foot on the brake... then it was easy as. can't recomend the foot on the brake enough!
    Feb 2007
    There was a topic on this not long ago. They said your not suposta use a rattle gun, when i tryed it it didnt work anyway.
    Using a long pipe on the end of a braker bar works well just dont stomp on it because i broke the auto gear box doing that. Your also suposta undo it while the car is on the ground, there is less that can go wrong, like the time i smashed my lip when the brake sliped.
    MK1 GLS 3door
    A4 B7 2.0T
    Jan 2009
    south west sydney
    Quote Originally Posted by Spyda View Post
    haha. my mate put his tooth trough his lip doing the same thing... chipped a bit of my paint haha
    Apr 2006
    Melbourne, Victoria
    i guess im screwed then cos the hub is not on a car, and the drive shaft has been cut on one side and removed from the outer cv joint on the other.
    Is it possible for me to install a drive shaft into the outer cv joint, then install the hub onto the car, put weight on the wheel then attemp the 2m pole?
    Any advice on outer cv joints and how they are attached to the drive shaft?
    CHeers,
    Jan 2009
    south west sydney
    It can be a **** fight trying to get them off the shaft. I ended up buying a complete shaft w/ boots cvs still intact. Was much easier to replace the whole thing
