Hello,
I have a set of hub assemblies with the outer CV joints but no drive shafts so there isnt much to stop the shaft from turning when i try to undo the drive shaft nut.
Any suggestions???
Cheers!
Hello,
Any suggestions???
Cheers!
Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
Get a big adjustable wrench to hold onto the outer CV (from the rear) and then support it/postition it so it doesn't move whislt you get your 30mm socket with a really long torque arm to undo the nut.
naturally, WD40, heat, rattle gun may also be of assistance.
i just realised that i can bolt a wheel to the hub! that should give me a bit more to hold onto!
that also works.
alternatively, you can get someone to jump in the car and squish the brake pedal as you stand on a 2m steel pipe.
87' MK2 GTI
13' MK7 TDI
i tried about a 2m pipe and still would not budge untill i had some on put their foot on the brake... then it was easy as. can't recomend the foot on the brake enough!
There was a topic on this not long ago. They said your not suposta use a rattle gun, when i tryed it it didnt work anyway.
Using a long pipe on the end of a braker bar works well just dont stomp on it because i broke the auto gear box doing that. Your also suposta undo it while the car is on the ground, there is less that can go wrong, like the time i smashed my lip when the brake sliped.
MK1 GLS 3door
A4 B7 2.0T
