Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: How to replace front wheel bearings
    Boronia VIC
    I had to change some wheel bearings today so I thought I'd shown you how it's done. (or at least how I do it)
    Loosen off the axle nut and wheel nuts.
    For the record this is a 3/4" breaker bar and the socket is 30mm.
    Jack it up and put it on stands.
    Pull the disc and caliper off.
    Support the caliper so there's no weight on the hose.
    Remove the hub. Two bolts on the strut, one on the ball joint and one nut on the tie rod end.
    Press out the drive flange.
    Press out the bearing after removing the circlips.
    Press the inner race off the drive flange. (They always get stuck on here.)
    So stuck in fact that I had to cut this off with a Dremel.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Boronia VIC
    This is a new bearing kit, you get a new circlips, new nut and bolt for the ball joint, a new axle nut and a new nut for the tie rod end.
    Put a new circlip in the outside groove.
    Press in the new bearing. I use a ground down old one as a drift.
    It's ground down just enough to slide through the hub with no resistance.
    Put the other circlip in now.
    This is a stuffed hub. The axle nut was loose and the inner race was overloaded. The diameter is actually 1/2mm down in the worn section. This one has the added bonus of a grinder scar from someone cutting off and old race.
    Put the backing plate on NOW. Use loctite.
    7? MK1 Caddy
    12 Amarok
    Boronia VIC
    Press in the drive flange. You need to be careful to press on the inner race so you don't damage the bearing. I use an old inner race here with an old CV inner on top to add a bit more height.
    Here it is from the back.
    And the front.
    Now it's all ready to re-install.
    It's very , very , VERY IMPORTANT that you do the axle nut up as tight as you can before you lower the car and that you do the nut all the way up before you move the car even one inch.
    Never, ever move the car with the axle nut loose or you'll stuff the wheel bearings.
    I got that press off e-bay for $70, second hand and rusty, it's been very handy.
    Pete
    7? MK1 Caddy
    12 Amarok
    Great write up as usual Pete.
    Especially about "not" moving the car without the driveshaft hub nuts being effing tight before you lower & move the car anywhere!!!!
    With the amount of wheel bearings I've done over the years, a press like that has been on the workshop equipment list of things to get for quite some time.
    Just to add a quick little tip.
    When reinstalling the Circlips in the grooves. I always like to fit the opening of the clip facing the top/up, so no dirt,dust, water or any crap can get into & sit in the circlip groove & cause rust etc.
    Sep 2009
    Chillaxing in Tas
    Silly question, but what is the Torque rating for the Nut?
    I know it has to be bloody tight, but is there a figure to follow?
    Good write up though mate!!
    <space for rent>
    Aug 2009
    Great write up.
    Boronia VIC
    Quote Originally Posted by golfworx View Post
    Cheers!
    Yep, I learnt that the hard way. I rolled that car back 1 metre to get better access to the hub and stuffed the race from the get go.
    I particularly like this style because of the big aluminium foot under the jack. I've used some of the cheap ones on the market now that have a 1 inch rod to press with and they suck as they tend to kick sideways. The big plate keeps things nice and parallel.
    Cool , must remember that for next time, although by the looks of the photos I've accidentally done just that!
    Pete
    7? MK1 Caddy
    12 Amarok
    Boronia VIC
    Quote Originally Posted by GRN_VAGN View Post
    Effing tight is a good approximation but 173 Ft.lb is the magic number according to Robert Bentley.
    Most people won't have a torque wrench that reads that high, you'll have to do the math on how much you weigh and work out the length of lever you need to stand on to achieve it.
    Pete
    7? MK1 Caddy
    12 Amarok
    Gosford Central Coast NSW
    the only thing i would add is too:
    > spray a squirt of lithium grease into the bore of the hub before pressing in the new bearing - this eases its ingress as well as making it nice and easy next time. likewise, a little spray onto the hub is a good idea.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Jun 2006
    Orange NSW
    Pete
    You've done early Kombi rear wheel bearings, haven't you Pete? Dad's got a "Special" bit of pipe for those bad boys. haha.
