This is a new bearing kit, you get a new circlips, new nut and bolt for the ball joint, a new axle nut and a new nut for the tie rod end.
Put a new circlip in the outside groove.
Press in the new bearing. I use a ground down old one as a drift.
It's ground down just enough to slide through the hub with no resistance.
Put the other circlip in now.
This is a stuffed hub. The axle nut was loose and the inner race was overloaded. The diameter is actually 1/2mm down in the worn section. This one has the added bonus of a grinder scar from someone cutting off and old race.
Put the backing plate on NOW. Use loctite.
