Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: How to replace front wheel bearings
  1. #21
    Ballajura, W.A
    hey Pete managed to cut the inner sleeve off but the outer one is still stuck in there do you have any ideas how to get it out without a shop press? could i use a hack saw blade to cut it out?
  2. #22
    Boronia VIC
    You probably could get it out with a hacksaw but you'll still need the press to put the new one back in.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  3. #23
    Ballajura, W.A
    Looks like its a trip to the garage then!
    ---------- Post added 06-03-2012 at 11:46 AM ---------- Previous post was 05-03-2012 at 07:25 PM ----------
    Just one more thing, Whats that big round ball thing you used to press the outer bearing out with?
  4. #24
    Boronia VIC
    It was just an old tow ball. I was just using it as a spacer.
    Anyone with a press will have an assortment of drifts to press stuf in and out with.
    7? MK1 Caddy
    12 Amarok
  5. #25
    May 2006
    Adelaide South Australia
    To put the camber adjustment bolt/nut in the correct position at reassembly, I put a small centre punch mark on the flange[as close as possible to the outside] & a corresponding one on the strut[once again as close as possible to the bolt flange] before I undo anything. I normally have a wheel alignment done ASAP but have found this procedure to be close on perfect.
    Numerous Mk1 Golf diesels
