Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: How does the rear sway bay fit up?
  1. #21
    blackgti1.8 Guest
    Regards poly bushes for the rear - choose a soft compound.
    You'd be surprised how much hard bushes will stuff your ride.
    Actually, a poor man's solution is to cut off the part of the standard rubber bush that protrudes, and then put a big flat washer on either side.
    On sway bars, some aftermarket bars mount backwards towards the rear.
    Avoid these, unless they have plenty of allowance for flexing - the axel and swapbars move in different arcs, which doesn't do much for any semi-rigid bracket that trys to keep them connected
  2. #22
    Jan 2006
    Ballarat, Victoria
    Quote Originally Posted by Tim
    I thought that was one of the points of upgrading the rear swaybar!
    True, however, fitting just the rear sway bar may degrade the handling - increase rear inside wheel lift off and increase understeer.
  3. #23
    Nov 2005
    Quote Originally Posted by Campaign
    have you actually just put on JUST the rear sway bar and tried it for yourself?
    because I can certainly tell you it does not increase understeer.
    MY16 MKVIIR - Option: Folded rear seats mode.
    MKI....#14....lost count.
  4. #24
    Point Cook, Vic
    its the opposite dude. If u increase the rear inside wheel lift that reduces grip in the rear which gives u that cool mid corner oversteer/turn in. Altho with everything there are limits. U dont want to increase oversteer to the point where it gets sudden and difficult to contain. the bar being fitted here is quite modest. Im sure the results will be quite an improvement.
    FOLLOW US ON FACEBOOK
Similar Threads
  1. Removing rear window mk2 gti
    By ausgolfer in forum Bodywork/Trim & Detailing
    Last Post: 19-01-2007, 10:13 AM
  2. Rear Sway bar
    By Green Mk3 in forum Mk3 Golf & Vento
    Last Post: 18-09-2006, 11:29 AM
  3. rear sway bar??
    By mollins in forum Mk1 Golf
    Last Post: 01-06-2006, 09:43 PM
