Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: How do you Rebuild a 16v
    if the 16v has a blown headgasket and stuffed rings, what is required in order to 'refresh' it properly.
    reseat the valves
    new rings
    head gastket
    whats else is involved?
    also is there any things you have to consider when putting a 16v on twin 45's??
    cheers in advance
    GM
    Quote Originally Posted by GoLfMan
    cheers in advance
    GM
    The price of a litre!
    An oil burning 16V might not need new rings but if you are pulling it down then they would be worth changing.
    I would definitely be changing the exhaust valve guides on any motor with 100,000 miles/160,000 KMs.
    what would be wrong with an oil burning 16v? parts wise what would be needed?
    cheers
    Aug 2005
    cheers
    I wouldn't toy around. I'd get a complete rebuild kit for piece of mind if I didn't know the history of the engine. That said, you can tell a lot as soon as you pull the head off.
    You can either re-sleeve the block - AFAIK gtimk5 has had success with this - or buy oversize 83mm or 83.5mm pistons. The stock bore is 82.5mm.
    www.eurospecsport is the place to buy parts.
    16v on 45s is hugely expensive: you need a good manifold, properly jetted carbs, a tune up, a new ignition setup (most yanks use MSD - also not cheap), an ABF water outlet (with some manifolds) etc etc. Not cheap
    so you can buy a full rebuild kit!
    A friends dad has the full porting and polishing kit so we will be tucking into the engine with porting and polishing (when i get one) as he is keen to help me build an engine.
    so its more economically viable just to convert my carby car to fuel injection? but im not looking at a cheap option, im looking for the power and straight forward option, which ever is easiest to obtain the most amount of street power possible.
    thanks for the link Valver!
    just had a look at the site Valver and I didnt see any rebuild kits that you speak of?!
    Aug 2005
    I don't think Eurospec sell the rebuild kits, but they're a good source for pistons
    These guys - http://www.mjmautohaus.com/ - claim to do the best deals on 16v rebuild parts, so send them an email and suss out what they can do.
    I ordered all my replacement parts from here:
    www.parts4vws.com
    www.germanautoparts.com
    www.gsfcarparts.com
    Had great service from all of them. Someone also recommended http://www.carmadillo.com/ but I never tried them out.
    And, most importantly, here's how to rebuild a 16v:
    http://forums.vwvortex.com/zerothread?id=195488
    This pic is very helpful, too:
    Vortex is the place to go for 16v info. The threads are endless.
    cheers for your help mate
    Camden, Sydney
    If you dont want to go crazy with the rebuild GolfMan, a lot of the parts are the same as an 8v motor. Headgasket and Rings for example.
    You could hone the bores, put new rings and then do some headwork, port and polish and a skim. You`d end up with a nice rebuilt motor, but wont have spent silly money.
    If you start buying pistons and resleeving blocks it gets expensive. Even a stock kr engine in a Mk1 is gonna haul ass.
    Throttle bodies are very expensive, use factor fuel injection, or go aftermarket. Fuel is never gonna get cheaper.
    Jul 2005
    Melbourne, Williamstown
    Hey Valver, I know you've had ABF's in the last 2 cars but do you know where I could find 83mm or 83.5mm pistons for a KR? All the aftermarket 16v pistons I could find were for 9a's or ABF's, except for the ones TSR used to sell in the 1.8KR to 1.9KR rebuild kit
    mk2 GTi 16v
    Corrado G60
Similar Threads
  1. Oldskool Polo Mk1 in Melbourne needs rebuild EOI
    By Golf Loon in forum Polo Mk1, 2 & 3 (86 & 86C, 1975 - 1994) Coupe, Sedan and Breadvan
    Last Post: 01-03-2011, 06:12 AM
  2. Yet another Tassie rebuild
    By el_foolio in forum Restorations, Conversions and Projects
    Last Post: 06-08-2007, 04:59 PM
  3. Bottom End rebuild Advice
    By smithy010 in forum Mk1 Golf
    Last Post: 28-10-2006, 11:13 AM
  4. carbie rebuild
    By GoLfMan in forum Mk1 Golf
    Last Post: 19-01-2006, 08:13 PM
