Results 1 to 10 of 13
Thread: How do I remove this part?
    Jan 2011
    Hobart, Tasmania.
    The silver metal trim around the door windows,
    There is no clear way to get these off without bending them as far as I can see.
    Cheers.
    Jun 2007
    Eastern Suburbs Melbourne
    there are two small clips that 'join' the two halves' (well, cover the join atleast) (i'm assuming you've got them off already)
    Then just take them off carefully. IIRC the top one first, from the back part of the door (side of the door with the door handle in it). Pull the Vertical piece outwards, then downwards and it should come out pretty easy.
    Don't worry if they bend a bit, they can be bent back pretty easily.
    i like volkswagens
    Jun 2006
    Orange NSW
    Just lift the tail up with a screw driver (put something under it so you don't damage your paint) and peel them off.
    They get a bit of a bow in them but that can be easily straightened. As long as you are careful not to kink them you should be ok to reuse them.
    Jan 2011
    Hobart, Tasmania.
    How do I get the clips off?
    Sorry for the noob question.
    Jun 2007
    small flat blade screw driver. O-ring removal tool, something like that
    i like volkswagens
    Aug 2009
    Main tool you need is patience!
    You gotta remove all the associated window seals btw, if you hadn't figured that out already.
    Jan 2011
    Hobart, Tasmania.
    What do o do to get around the non fixed front quarters?
    Aug 2009
    Drill the rivet in the door (behind the door card) that holds the sliding window channel, remove door glass (the big bit), undo the screw at the top of the sliding glass channel behind the felt crap, wiggle the vent window free and remove the whole lot from the door.
    You will have seriously ass naked door by the end of this.
    Jan 2011
    Hobart, Tasmania.
    Ok cool and one last question is how do I remove the plastic bit that overlaps the door card at the top?
    Aug 2009
    Without breaking it?
