Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: How do I make the best 16v for my style of driving?
    After doing some research it seems a good combo is the 9a block with the ABF head. The 9a block is normal height so no clearance problems if I decide to fit the fuel injection off the Seat and the ABF head has the following advantages over the 9a head:
    Small 27mm dia exhaust valve on 27mm seat for improved flow of hot exhaust gas
    Cooling passages in the exhaust port to reduce hot spots and improve durability
    Cooling channels in inlet port to improve/vaporisation and wall warm up.
    Cooling passages in the combustion chamber to reduce hot spots and improve durability.
    Improved squish areas working with revised piston.
    Optimised valve shrouding on the inlet toward spark plug hole
    optimised head shape around the shrouded part of the exhaust valves.
    Reduce valve guide protrusion.
    Reduction in port casting imperfections.
    In/Ex Port flow improved over "51***373" heads.
    Late model 9a motors had the same head casting numbers as the ABF motors so there shouldn't be any problems fitting the ABF head. The only difference was the inlet and exhaust cams.
    This is the bit that convinced me to use the ABF head. It develops more power and it has a similar torque curve to the 9a so running the wilder ABF cams isn't going to kill my low down torque.
    Lots of info here.
    A VW 16v camshaft study.
    Oct 2013
    ACT
    Why don't you just run the ABF with a small turbo?
    Only The Good Die Young 45
    For a better ride, go WIDE!!!
    VS Commodore V6 Berlina- FOR SALE
    1979 Golf Mk1- http://www.vwwatercooled.com.au/foru...one-92128.html
    I don't want that much HP. This car is being built to do the drive to Canberra and back each day and I don't want something that's too fast like my old Bolwell Nagari (1000kg, 350 hp) which kept eating my licence.
    I like the idea of having something that will overtake cars but still need a bit of planning before I overtake.
    Gosford Central Coast NSW
    Keep it basically stock then I reckon. It should be perfect!
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Oct 2013
    ACT
    Yeah, just rebuild the ABF with a few internals changed for a bit more power.
    I'll rebuild the 9a I got from you. It needs a rebore and new pistons which isn't cheap but should give me an engine that's good for another 20 years.
    From all the posts on overseas forums the ABF in a MK1 isn't a good crusing motor. Great for racing, lousy for relaxed driving.
    Oct 2013
    ACT
    Well, there you go then. And I am sure you can get a bit more torque out of the 9A to make it a better cruising motor than it is standard.
    I am surprised you aren't doing the ABF for the Mk2 and the 9A for the Mk1?How do I make the best 16v for my style of driving?How do I make the best 16v for my style of driving?
