Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: HOW CAN YOU GET A HOLD OF THESE TIRES?????? FOR A MK1
    Nov 2005
    can someone tell me where to get a set of 15 inch 40profile tires?????? its doing my head in harddd
    wabit
    16valvertwin45s Guest
    you sure they're 15s and not 16's
    a common mod in europe is to use narrower tyres than the recommendation to give tyres that rubber band look telltale is the stretched side wall
    Nov 2005
    nah im asking for 15''s
    wabit
    Aug 2005
    Prahran, Vic
    how come you want 15/40? 45s will be a lot cheaper
    Your best bet is to get a toyo agent to source some TR-1's in 195/45/15. Then again they aren't that different to 195/50/15 and I sourced Toyo TPG for $110/corner.
    RUBBER FETISH CONDOM
    http://www.mytyres.co.uk/start.html
    sydney
    will let you know what i find in the next week or two
    I would have gotten wood from the picture message you sent me.. But I was sniffing Nitro, so i already had it. Hahaha.
    Feb 2006
    Hobart TAS
    Yokohama do a 185/50-15, this is a similar side wall height to a 195/45-15 but a bit narrower. Good for the stretch look.
    Feb 2006
    Hobart TAS
    If ya want to go really nuts Bridgestone and Continental do a 175/55-15. I'm putting some on the front of my splitty. (it's pretty low).
    Feb 2006
    Hobart TAS
    Now these are nuts!!
    Aug 2005
    The load rating on the 165/45/15s doesn't meet regulations on a Mk1 here. I was going to import some to put on my old 15x7s (now on Ben's little minter!!) and called up to check and was given a big thumbs down, which was strange. I called back and talked to someone else and got the same answer
    The continental versions are near impossible to find anywhere but Germany or Holland. I found a few in this size available in the US but they were all cheapo jobs.
    I'm sure you could fit them and no plod would have a clue but my car still has to pass the pits
    They look great, though Stretch on a 7" is quite a lot, however and the ride quality would be terrible!!
