Results 1 to 4 of 4
Thread: How best to incorporate driving lights
    Jul 2005
    Newcastle, NSW
    I have a LS that has had the GTI grille added with driving lights. The lights that came with it had no electrics, so I just procured some that do.
    Now I am planning on wiring them in on a separate relay to the main lights but I was wondering how they would have originally switched on the gti? Was it via the stalk, or a switch on the dash?
    If it was a switch where abouts and what was that switch like?
    Cheers!
    BTW - hoping to have her through rego by the end of the week, mid next pending getting into a mechanic to do a couple of things. Can't wait!
    On the standard GTI they were high beam's/driving light's or what ever you want to call them.
    They were operated just off the indicator/high beam stalk.
    They Campaign's were fog light's & operated off a switch on the dash panel.
    If you want to go for a separate switch, I'd get another rear screen demister switch, wire it into a trigger for a relay & put it in the dash panel in the spare blank above the radio.
    Look's factory fitted then.
    Hope this help's.
    Jul 2005
    Newcastle, NSW
    Great advice!
    I think I will go down the switch in the dash option - mainly because there is a greater liklihood that I will like the flexibility of not having all of the 4 lights lit up under high beam on a regular basis.
    Thanks!
    Dec 2007
    Somewhere in Melbourne, Victoria
    how about optional high beam with lights coming on when high beam is switched on or you can over-ride to switch off!
    Here is a circuit diagram to put higher wattage globes into a GTI/Cabrio, just run a swtich to dash from power source and bobs....
    http://www.vintagewatercooleds.com/t.../Headlight.htm
    1991 Golf GTI Manual - Tornado Red (Little Red Wagen)
    1998 Golf Cabriolet Manual - Black Magic Pearl (aka Rommel's Panzer) Deceased/written off
    1993 Golf Cabriolet Manual - Alpine White (aka Hitler Youth Wagen) Deceased/written off
    1976 Golf LS Manual - Bronco Brown (aka Roadrunner) Deceased/worn out
