Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Hmmmm Nice.
    Aug 2006
    Melbourne VIC
    Hmmmm Nice.
    Before (extreme control arm/tie rod angle, tie rod in stock down pointing position)
    Aftter level arms, no extreme angle, excellent handling
    notice the balljoint is now pointing up, that is PMW spacers and tie rod flip kit,
    Jun 2007
    Eastern Suburbs Melbourne
    The A arms have a spacer under them do they??
    Never heard of that before. Heard about the tie rod flip kits though.
    i like volkswagens
    Yep.
    They are tie-rod arm flip kit's which requires drilling & a new tapered bush & also the Ball joint extension kit's.
    Valver has the same type of ball joint kit's fitted to his mk1.
    It's to eliminate bump steer.
    Nov 2005
    i had a chat with my old man about this.... he was sayin something like it could be unsafe and could be weaker than orig setup? could this be true?
    dom
    Quote Originally Posted by WABIT View Post
    dom
    It can be if the material's used aren't upto scratch!
    The ball joint extension's I read about are made out of some extremely tough stuff, as the bloke said it was a pain to machine.
    I'm sure preeny could tell you more about what should be used.
    Jun 2006
    Orange NSW
    Quote Originally Posted by golfworx View Post
    Quite true.
    Mild Steel would NOT be an option. I'd use 4140 or possibly 4340. 4340 is pretty tough to machine, but you can do it.. I don't have too much trouble but i'd much prefer to be machining 4140.
    Both these steels are pre hardened and tempered and are extremely strong. The absolute best to make this kind of equipment from (readily available..).
    If the bloke said it was a pain, i'd say it was 4340 or EN26 (The stuff Terry Sainty makes his Billet Top Fuel crankshafts from).
    The main thing would be that you ensure you have no sharp corners, so you want a radius in every shoulder. This may mean that you will have to reduce the diameter in the corner (if what ever butting up against it does not have clearance to allow for it) to allow for the radius, but it is far stronger because it eliminates a potential crack point.
    I hope that makes sense. Let me know if you want more info. Hell, I might even do a drawing for you!
    Sep 2006
    West Sydney
    Are those pictures at the same ride height? It looks like the "after" picture is of a higher sitting vehicle than the "before", which to me isn't really a fair comparison when looking at the control arms.
    I can appreciate the tie-rod flip though - does the knuckle-section where the tie-rod threads through need to be bored out, or does the tie-rod flip kit cater for that? I've looked at it on my Mk3 and the angles are off so you wouldn't be able to thread it through unless the hole was bored out a little.
    Mar 2006
    brisbane
    Where did you buy these?
    I have seen them on vortex one time and sure there would be a few people here who would love their roll centers above the road..
    very nice mod.
    Aug 2005
    Mine were made by Performance Machine Works in the US. They are bloody expensive, but not the sort of thing you want to fail.
    They're only made in 17 and 19mm spec, so you need at least late model hub carriers, which aren't the easiest thing to come by at the end of the day.
    Aug 2006
    Melbourne VIC
    Yeah I got this off Vortex but they are the same height cars that run the same wheel specs.
