theres a lot more to it than cable shift and rod shift.
The cable (02a and later) boxes are more modern, stronger and (significantly)heavier. They will take more torque and have longer ratio's available. They also havea more conventional clutch layout allowing the use of bigger, more modern clutches that will again take more torque.
The 020 boxes are very good considering the age and for a 5 speed transaxel with the strength they have are pretty lightweight. Personally, I also find that the 020 with rod shift is a faster gear change than the 02a.
Its not likely you will be able to make more torque than a 210mm 020 clutch can handle, so if i were you I'd stick with the 020 - but you could have any number of other reasons to run an 02a anyway - just depends on what you are going to use it for.
If your going to beat on it and do burnouts everywhere, maybe you should opt for the 02a.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
