Results 1 to 10 of 13
Thread: Help needed
    Jan 2010
    Baulkham Hills
    Help needed
    I am having real trouble removing the front bumper of my golf. The rear bumper was easy as the bolts were in the boot, but the front bumper is proving more difficult.
    i know that on the left (looking into the engine bay) the bolts are accessable with a little fiddling, but on the right, they are tucked away under the battery plate and next to the radiator.. i'm going to have to prop up the front and go in from benieth aren't i?
    Feb 2008
    Melbourne.
    Josh,
    It'll depend on which model you have...I can access both sides of my front bumper's bolts from above, but if it is fiddly for you, then from below may well be easier!!
    Children(VW) who have left home, among others:1966 VW 1300 Deluxe Bug(Harbour Blue)1966 VW 1300 Steel Sunroof Bug(Ruby Red), 1971 VW 1600 S Bug(White) 1972 VW 25th Ann. Bug(Avocado) 2000 VW Golf Mk IV GTI 3 door(Metallic Black Magic), 1985 VW Golf Mk 1 GLS Cabriolet (Metallic Gun Metal) Current: 1985 Mercedes Benz 280CE Coupe(Midnight Blue)
    Aug 2009
    Torquay, victoria
    i can seem to access both of mine from up top. the one under the battery was harder but still can be done.
    Aug 2009
    Man, seems like you're struggling with simple stuff. You can reach it under the battery tray.
    My ratchet-spanners help to undo them. Before you get at them crawl underneath and soak the bolt heads and holes with WD40, then undo it the next day.
    13mm bolt heads IIRC? Or someone correct me.
    yeh from memory they are 13mm's
    ratchet ring spanners help alot. I can get them out from the top or the bottom of the car. Too easy!
    Sep 2009
    Chillaxing in Tas
    13mm yes,
    And he is stuggleing with simple stuff, but he has also mentioned he is very Car nooby haha
    <space for rent>
    Jan 2010
    Baulkham Hills
    i feel stupid now... hahahahaha FINE i wont ask for help!!
    Aug 2009
    Ask for help, just do it in a single thread, like your car's thread.
    Jun 2007
    Eastern Suburbs Melbourne
    Quote Originally Posted by IH8 View Post
    yea, clutters the forum up a lot less. I also suggest getting a haynes manual too!
    Sometimes you have to thing out of the box with a few things, but most of a mk 1 is pretty simple.
    Use a 13 socket with a small extension. I find it's best to stand next to the fender and facing forward (ie facing the same way as you would be driving) and excessing it that way.
    i like volkswagens
    Jul 2005
    Newcastle, NSW
    My tip is to get the following tools together as a minimum - and you buy say Repco brand you will get a good kit for value money (not chinese cheap though)
    Socket set - Metric 6mm - 32mm
    Screwdriver set - Philips and Flat
    Open ended/Ring spanner set - 6, 8, 10, 12, 13, 14, 15 should be enough
    Hammer
    Good trolley jack
    That should get 90% of a mk1 apart and back together again!
