The drive shaft bolts are a torx bit i think, 8 point bit, they smash into a 6mm allen key perfectly. It is well worth the $8 or so on a allen key socket.
I so miss the golf, really regretting the sale. The webber is fantastic, they dont usually have a return line, my old one we put a return line in because the std mechanical fuel pump tended to over fuel it, just crimp the return line a little to reduce the flow.
Schultz Mechanical in willetton have a dyno and a heap of spare webber bits, it is well worth getting it tuned to the car and try and get a choke for it! Tell them i sent you and they should do a good deal.
If you are having any dramas give me a bell
-Jamie
76' Mk1 Rally Car, 1800 8v haltech ecu
94' Fairmont Ghia, v8, big cam, leather, perfect for towing golfs
89' EA ex taxi, lpg, cheap and easy
