Results 1 to 5 of 5
Thread: Help me open up secondaries!
    reborn Guest
    I have wacked a webber on the car.
    We have made up a bracket to position the cable in the right spot however secondaries barely get moved. I went out and bought a half moon cable thingy from a gemini in the hope it would roll off that... I am yet to get the tie off for the cable and see if this solution works.
    How have others overcome this problem?
    Thanks.
    Gosford Central Coast NSW
    i found the best angle to pull from was directly across the throttle shaft from the firewall side towards the rocker cover. with a 20mm lever arm you need about 25mm pull through to get full throttle movement.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    What sort of carb arrangement is it?
    - Vacuum secondaries
    - Mechanical progressive secondaries
    - Mechanical secondarie's that open at the same rate as the primaries.
    Aug 2005
    Howdy..
    here is a picture of the weber on my parts car... i am assuming you have a down draft?
    Good luck. If you have a single dcoe i may have a pic lying around of suzi sierra conversion carb setup i did with with my brother a while back
    reborn Guest
    Quote Originally Posted by golfworx View Post
    Hey, I think they are progressive mechanical secondaries.
