i found the best angle to pull from was directly across the throttle shaft from the firewall side towards the rocker cover. with a 20mm lever arm you need about 25mm pull through to get full throttle movement.
I have wacked a webber on the car.
We have made up a bracket to position the cable in the right spot however secondaries barely get moved. I went out and bought a half moon cable thingy from a gemini in the hope it would roll off that... I am yet to get the tie off for the cable and see if this solution works.
How have others overcome this problem?
Thanks.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
What sort of carb arrangement is it?
- Vacuum secondaries
- Mechanical progressive secondaries
- Mechanical secondarie's that open at the same rate as the primaries.
Howdy..
here is a picture of the weber on my parts car... i am assuming you have a down draft?
Good luck. If you have a single dcoe i may have a pic lying around of suzi sierra conversion carb setup i did with with my brother a while back
