Page 1 of 8 123 ... LastLast
Results 1 to 10 of 74
Thread: HELP: Leaning out??!?!
    Exclamation HELP: Leaning out??!?!
    Driving my mk1 back to back with Jarreds mk1, mine is HEAPS slower and WAY LESS responsive.
    its pinging heaps althought its been timed properly and its leaning out at 5g's.
    its breathless and it shouldnt be with a whopping DCOE on it and a 2" exhaust with extractors.
    HELP
    Jun 2007
    Eastern Suburbs Melbourne
    it's also got 98 octane in the tank.
    Engine is a bit of an unknown unfortunately...
    i like volkswagens
    Nov 2005
    newcastle
    timed properly?
    Quote Originally Posted by GoLfMan View Post
    its been timed properly .
    how was this done? what did you use as TDC marker? flywheel marker sometimes doesnt line up if its been put on wrong.
    what about plugs, leads and dizzy cap. Are these new/old/cheap-and-nasty?
    have you got plenty of fuel pressure from your pump? (crap pump or dirt in tank can give lean mix)
    good luck
    mike
    TDI mk1 on the road!!
    Jun 2007
    have you still got that fuel pump from stu? you'll need a reg too
    i like volkswagens
    Quote Originally Posted by mollins View Post
    good luck
    mike
    yup it was timed from the TDC marking on the flywheel.
    dizzy cap, sparkies and leads all need to be replaced, how do i check the fuel pump, what if the carby is jetted wrong?
    Camden, Sydney
    An engine is as good as its worst companant.
    Change the cap, leads and rotor for starters. Dont use crap blue leads.
    I usually check the timing belt is timed properly and then with the dissy cap off, check the arm is pointing at the corner of the block. TDC marks on flywheels can be wrong.
    How do you know its lean?? It could be heaps rich which will make it slow too.
    The engine could be a dog's breakfast!!!!
    Also, one thing I've mentioned to you before. Your trying to feed a DCOE with a stock Mk1 1.6L fuel pump unregulated. Of course it might lean out. Your using more fuel than it can probably supply.
    You really do need an electric fuel pump & a regulator.
    Loon's also right. It's only as good as it's weakest link. I've been through this with you I think. Lead's, plug's, cap, rotor button, Point's & condensor.
    Also I don't know how flywheel's can be fitted incorrectly. I honestly don't They are dowelled! Well all the ones I've removed & refitted are.
    Boronia VIC
    Quote Originally Posted by golfworx View Post
    I don't know how either but here's proof. This is my GX with the timing mark centred in the inspection hole.
    Pete
    Jun 2006
    Orange NSW
    I doubt it. My mk1 with a 1.7 with all the work done to it, running a 44 IDF and i'd estimate putting out around 130hp didn't have trouble with fuel supply problems. And i was using the stock pump.
    Boronia VIC
    Sounds like a couple of problems there.
    Firstly don't expect to get the same low rpm torque as Jarred.
    His carb and manifold setup should be far more tractable. (long runners, small venturi etc)
    What size venturis are in that DCOE? You might need to go a bit smaller if there's sufficient fuel pressure. You may not be creating enough vacuum to draw the fuel through.
    I' try removing the T piece if it's still fitted in the fuel line, then an electric pump, then the venturis.
    Pete
