You guys are missing one prominent point here... Josh had the same problem with this carby on a DIFFERENT ENGINE.![]()
thanks Preeny!
this carb had the exact same problem as im having now on Jarreds engine and that fuel pump is working perfectly!
i get the carby rebuild kit tommorowso ill let you all know what size the jets are and ill take some general photos of the condition
and while im at it ill check all the TDC markings and make sure they are juuusssttt right! and put the dizzy in properly.
ok updates!
ripped it apart and heres how it stands:
Venturi's: 33
Pump Jet: 40
Main Jet: 135
Float Weight: 26
i have a feeling the mains are too small??
also putting in the new needle and seat i think the float level is to low. hmm how can i measure this accurately before adjusting anything?
