Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 74
Thread: HELP: Leaning out??!?!
  1. #51
    Jun 2007
    Eastern Suburbs Melbourne
    Yes - your leads must be 180° out too.
    Pete
    We did line up, from cyc 1 was lined up with lead 1 at the marking on the dizzy, while the engine was at TDC (we check by removing the spark plug trick, it is lined up with the flywheel TDC too)
    Wouldn't it fire on atleast on cycl 1? and not the rest if we mixed it up?
    EDIT:
    We havn't looked at cam pully markings yet. is it possible the intermediate shaft is out of whack from when josh changed the timing belt, hence why the dist was so far out?
    i like volkswagens
  2. #52
    Oakleigh VIC
    Yeah, that's right.
    By the way, that wouldn't make any difference to the performance.
    So long as all his leads are 180° out
    Pete
  3. #53
    Jun 2006
    Orange NSW
    Pete
    Yeah, but it wouldn't have been firing on all cylinders if it wasn't.
    Please tell me you guys made sure it's firing on all cylinders?
  4. #54
    Oakleigh VIC
    EDIT:
    Ummmm I'm not quite understanding you at this point.
    This is a 4 stroke motor, the pistons go up and down twice for every rotation of the distributor. To make sure you're on the firing stroke look for the dot on the motor side of the camshaft pulley to line up with the rocker cover flange at the front of the motor.
    Pete
  5. #55
    Oakleigh VIC
    Could explain the "pinging" at all RPM
    Pete
  6. #56
    Jun 2006
    Orange NSW
    Pete
    Yeah true.
    So hard to help out when you can't be there to see what's going on..
  7. #57
    how about this....
    a slab of the persons favourite bevvy to whoever helps me get this dam car sorted!!!
  8. #58
    Quote Originally Posted by golfworx View Post
    Turn it over again.
    Don't just go off the flywheel mark. Also use the cam pulley marking's. That's what there there for.
    If it's 180 out, it won't run at all & spit fuel out the carb, most likely with flames too!
    we whipped out sparky #1 and TDC'd it that way and the flywheel marking was in the right spot too.
    i recon its 180 out now, it wont run and it does shoot flames out the carb.... HMMMM
  9. #59
    Quote Originally Posted by GoLfMan View Post
    You've lost me fella's sorry.
    If you've got a manual, read the section about removing & refitting the dizzy & read it carefully TWICE! Then follow the instruction's to the letter.
  10. #60
    Oakleigh VIC
    how about this....
    Nah, this is way more fun!
    Pete
