-8V head came in cross and counter flow configs. Most common is counter flow. Some late model seats (ie, 99) had 1.6 8V with a cross flow head. The ABA is an american motor, but is a 2.0L 8V with a cross flow as well. Few floating around these parts, or pick on up dirt cheap from the US.
-In australia, the first EFI 8V was in the mk 2 GTI, in '90. It's a bit shonky. (digifant)
-16V's came in mk 2's, mk 3's and seat cupra (which is itself a bit of a cross between mk 2 and 3). Also came in passats (b3), and a couple seat toledo's. best chances for a 16V in OZ is to ring up Golf Loon, or find yourself a wrecked seat. mk 2 had 1.8l KR, the others were mainly ABF's, except the passat, which was a 9A. No mk 3's in OZ came factory with 16V engines, nor did mk 2's (imports only). Just the Seats only. Yes, 16V's make more power and torque than 8V's. This is important for track work. Worked 8V will only have the about the power of a standard 16V. (generally)
-There are many different gearbox codes. Late model mk 1's, mk 2's and mk 3 (non VR6) all run 020 5 speed box. (and all 8V seat ibiza's, cupras and toledo') They all have different codes. Search on the forum, there are a couple links which list all the different codes and thier ratios and FD's.
Read Pete Jones 's threads (wreck to race) which will have ALOT of very useful information in it about what you're planning on doing.
My personal recommendation (if you want to build a serious car, and spend a serious bit of money) Buy an ABF, get a ported head from the UK or US, and run it on standalone with big cams. If you're really serious, drop in some new pistons and up the compression. Should be close to 200HP there.
hope this helps.
