Results 1 to 10 of 19
Thread: help.. fuel problems!
mollins help.. fuel problems! 03-04-2006, 10:43 PM
Guest Check it again 04-04-2006, 07:11 AM
Guest I had a similar problem years... 04-04-2006, 07:21 AM
Golf Loon Yeah 30 year old petrol tank.... 04-04-2006, 08:34 AM
Guest Slide a screen filter (like... 04-04-2006, 11:20 AM
mollins ok ... the new filter is... 04-04-2006, 06:04 PM
Golf Loon Thats odd. Ive never seen one... 04-04-2006, 06:35 PM
Guest Check length of pushrod???? 05-04-2006, 09:08 AM
Guest check the neck of the fuel... 22-04-2006, 10:24 AM
gtimk5 Make sure the return line has... 22-04-2006, 10:55 AM
Guest I'm not saying that it... 22-04-2006, 06:40 PM
Guest There are two types of... 22-04-2006, 06:43 PM
gtimk5 Yeah, thats right syncro.... 22-04-2006, 06:57 PM
mollins ok... im sure i have... 22-04-2006, 07:44 PM
Guest A bit off the wall....but... 22-04-2006, 08:08 PM
gtimk5 Petrol tank is different, no... 23-04-2006, 08:55 AM
ausgolfer :lol: :lol: :lol: 23-04-2006, 10:28 AM
Guest Once you have blown out your... 24-04-2006, 09:20 AM
worm Is the fuel system meant to... 07-05-2006, 02:21 PM
    Nov 2005
    newcastle
    hi guys
    my car has been having many fuel pressure problems lately...
    it was dieing completely after prolonged loads (big hills) or after i gave it a sound flatfooting whilst showing those civic boys what a real car goes like... so i had the feul pressure tested and found out it was bugger all!
    so i gave it a new fuel pump, the mechanical sort, (one i had in my garage which i thought was brand new) and that seemed to fix the problem... for a while
    about 500 k's later...
    it started to do it again... so i replaced the fuel filter which i originally thought was ok... but once i cracked it open after replacing it... i found out it was reasonably full of crap
    that seemed to fix it for a while also...
    BUT NOW ITS DOING IT AGAIN!!!!!
    so.. could the crappy filter have wrecked my new pump that quickly?
    or is there another possible issue causing all this?
    and also im wondering if theres a better set up for fuel delivery for an 1.8 with an oversize carby?? eg. electric pumps?? as now would be ideal for a swap..
    thanks boys
    mike
    TDI mk1 on the road!!
    imported_brackie Guest
    Check it again
    First thing to do is to check your fuel filter again. If it's blocked you may need to clean your tank out (carefully!).
    syncro Guest
    I had a similar problem years ago. Put some Nulon in the tank then bought a handful of VW fuel filters and put two in line. Started changing the one closest to the tank daily for a week then every second day, then every fourth day etc.
    The one closest the carby only needed replacing once so the dirt/water didnt damage anything.
    Camden, Sydney
    Yeah 30 year old petrol tank. Buy 6 or 10 of the plastic filters and keep swopping em untill they dont foul anymore. 2 inline is a good idea syncro.
    Always keep the tank quarter full and it wont suck the cr@p down your fuel lines.
    If you use a low pressure electric pump, you need an accumulator too. I have all the bits in my garage, but they are not much new.
    Golfwise Guest
    Slide a screen filter (like on spray guns) over the end of the pick up/sender unit in the tank as well.
    The ole tank, shes full of crap.
    Nov 2005
    newcastle
    ok ...
    the new filter is one of the ones with the transperant casing and it doesnt look bad at all...
    so today i replaced the rubber fuel hoses which seemed to be cracking (as i thought it might be sucking air) and that didnt help
    then i found an old fuel pump off an old 1600 i have and when i went to swap it over.. i noticed a wierd rubber gasket was between the block and pump holding the fuel pump about 5mm further out from the block...
    so i got rid of the gasket/spacer thing (after checking it wouldnt break anything)
    and my pump started working properly!
    ive been for a little drive and it seems to be better.. i can now see the fuel at a much happier level in the filter so i think its solved the problem...
    but i'll see ... these things have a habit of haunting old cars for ever
    thanks guys
    mike
    Camden, Sydney
    Thats odd. Ive never seen one without the plastic block. Check it doesn`t leak oil.
    syncro Guest
    Quote Originally Posted by Golf Loon
    16valvertwin45s Guest
    check the neck of the fuel filler pipe its prone to rusting and clogging the lines up ,new ones are still available at vw dealers
    Apr 2006
    Hobart,Tas
    Make sure the return line has the restrictor in it. Had an earwig, (small bug) in the metal pipe years ago restricting the flow to the pump
Similar Threads
  1. VW Engine Number Chart
    By Golf Loon in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 14-09-2009, 03:20 AM
  2. Diesel Fuel lines
    By smithy010 in forum Diesels
    Last Post: 18-11-2006, 06:04 PM
  3. Getting fuel in the carbs
    By worm in forum Mk1 Golf
    Last Post: 22-04-2006, 05:25 PM
  4. 1.8L CIS K-Jetronic injection problems
    By Anonymous in forum Mk1 Golf
    Last Post: 01-08-2005, 09:54 PM
