Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Help - Brake lights dont work!
    Sep 2005
    Maroubra Beach
    I pulled out the 2 wires that go into the switch. And replugged them still nothing. I have a spare Master cylinder lying around so ill check if a switch is on there that i can pull off.
    cheers let u know how i go!
    Camden, Sydney
    Like Brackie said Costa.
    There are two switches on the M/C, in case one fails. Usually both fail and then you have no brakelights.
    Check with a bit of wire and replace the switch.
    Another option is to just wire a mechanical switch directly onto the brake pedal.
    The Mk1 brakes lights aren't too good at the best of times.
    Perth. WA
    Quote Originally Posted by golfworx
    Golfworx has the idea...
    This is the way mine have been for 20 + years... Between VW's reverse light switch and brake light switch they couldnt get it right...
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Sep 2005
    Maroubra Beach
    all sorted tried the ire trick on the brake switch no lights.
    So i called Matt and he said its the Fuses for sure.
    Played with the fuses and now its all sorted thanx guys!!!!
Similar Threads
  1. Brake reservoir lid
    By gman in forum Mk3 Golf & Vento
    Last Post: 14-01-2007, 01:05 PM
  2. Golf Mk1 brake confusion
    By tassie_euro_mk1 in forum Mk1 Golf
    Last Post: 21-07-2006, 05:47 PM
  3. Brake lights
    By gotrice in forum Mk1 Golf
    Last Post: 20-01-2006, 10:33 AM
  4. No Brake Lights????
    By crazygee in forum Mk1 Golf
    Last Post: 30-05-2005, 10:58 AM
  5. A brake story...
    By imported_brackie in forum The Audi Quarter
    Last Post: 23-05-2005, 10:20 AM
