Results 1 to 8 of 8
Thread: help
    help
    i was again today working on taking off the inlet manifold. but the cooland hoses that connect to it have no place on the new one. what do i do with all the things that dont connect to the dellortoes like those coolant hoses?
    syncro Guest
    DO NOT BLANK THEM OFF They must be connected together the same as they are on a 1.6 GTI. You may be able to use the small "U" shaped hose from an early GTI for a neat engine bay look.
    ah so just connect them together? i took the pipes off so i have to reconnect.
    syncro Guest
    Either that or drive around with the heater on continuously so that the water will flow correctly around the head.
    i think i will connect the hoses thanks 4 the advice.
    cheers mate
    Camden, Sydney
    Yeah a neat U is better than a huge loop. Havin fun with those dellortoes?
    Perth. WA
    Quote Originally Posted by syncro
    also note there is a restrictor in the coolant line when using the small U shaped pipe. At a guess the hole would be about 10 mm.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Quote Originally Posted by Golf Loon
    there not in yet this is a saga of me taking out the existing manifold
