If there's no power at the fuse then something is wrong. When the demister switch is turned on (together with the ignition switch) there should be power at the fuse.
Are you checking the right fuse? I have a Hayes manual and a Bentley and both have the wrong wiring for my fusebox. My car was probably rewired sometime in it's 33 year past by someone who had no idea what they were doing.
Paul
