Hmm.. I don't know if something else is wrong now but I can't get the headlights to work again using the above method at all anymore.. this is driving me nuts
I THINK I FOUND THE PROBLEM!
I was fiddling around with the highbeam stalk because I read that pulling it back should allow everything to turn on. This didn't work for me. But then I moved it up a little bit and everything turned on! So its probably the indicator/highbeam stalk thats faulty.
Is this fixable or how do I go about getting a new one? Thanks in advance.
Damien
Sorry to take a while to reply - had to find my receipts.
My notes in my log book went something like this:
29/1 (Rain) Wipers not working, nor interior fan, rear window demister and fog lamps - no power to fuses.
30/1 wipers etc working fine
2/2 (Rain) wipers etc stopped working - left car under shelter - working again.
6/2 (no rain) Relief/X-over relay intermittent fault –> no wipers etc
Because the fault became intermittent and unrelated to rainfall, I concluded that the relay was failing. Since I replaced it over two years ago, the problem has not recurred.
I purchased the relay from Volkspower for $33 and the part number on the receipt is 7MO 951 253A
On my wiring diagram the relay was J59 and I think it was at position #8 on the relay panel.
I am interested to hear how you resolve the problem
Paul
Hey Paul,
Turns out that my problem was with the ignition switch all along.. bloody thing! I also had some corrosion on a few of the fuses but I don't think they were to blame..
Thanks for getting back to me!
Damien
HA!
now im not one to say to people "i told you so" usually,
but mmmhmmm... ill leave it at that.
glad you got the problem sorted anyway mate.
