Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Headlights/Fan/Wipers not working.. help!
    Jul 2007
    Canberra
    I THINK I FOUND THE PROBLEM!
    I was fiddling around with the highbeam stalk because I read that pulling it back should allow everything to turn on. This didn't work for me. But then I moved it up a little bit and everything turned on! So its probably the indicator/highbeam stalk thats faulty.
    Is this fixable or how do I go about getting a new one? Thanks in advance.
    Damien
    Jul 2007
    Canberra
    Hmm.. I don't know if something else is wrong now but I can't get the headlights to work again using the above method at all anymore.. this is driving me nuts
    Jan 2006
    Ballarat, Victoria
    Relief/X-over/Load Reduction relay
    Quote Originally Posted by swiss7 View Post
    Hey guys,
    Great to get so many replies!
    I suspect it might not be the ignition switch because I bypassed that by shorting the two wires in the ignition myself and the wipers/etc.. still didn't work.
    It wasn't raining that much at all really. Had a bit of rain earlier on and the wipers were working alright for the whole time. Hadn't rained for a while when we had dinner and it stopped working.
    Campaign/Paul: I would be interested to find out more about how you fixed the problem!
    Sorry to take a while to reply - had to find my receipts.
    My notes in my log book went something like this:
    29/1 (Rain) Wipers not working, nor interior fan, rear window demister and fog lamps - no power to fuses.
    30/1 wipers etc working fine
    2/2 (Rain) wipers etc stopped working - left car under shelter - working again.
    6/2 (no rain) Relief/X-over relay intermittent fault –> no wipers etc
    Because the fault became intermittent and unrelated to rainfall, I concluded that the relay was failing. Since I replaced it over two years ago, the problem has not recurred.
    I purchased the relay from Volkspower for $33 and the part number on the receipt is 7MO 951 253A
    On my wiring diagram the relay was J59 and I think it was at position #8 on the relay panel.
    I am interested to hear how you resolve the problem
    Paul
    Jul 2007
    Canberra
    Hey Paul,
    Turns out that my problem was with the ignition switch all along.. bloody thing! I also had some corrosion on a few of the fuses but I don't think they were to blame..
    Thanks for getting back to me!
    Damien
    Mar 2007
    tas
    HA!
    now im not one to say to people "i told you so" usually,
    but mmmhmmm... ill leave it at that.
    glad you got the problem sorted anyway mate.
