Results 1 to 10 of 13
Thread: Head lights dull
    SPC Guest
    Head lights dull
    Head lights are no where near bright enough. High beams are fine but normal lights are as dull as.
    Someone hinted that it is a common theme with the mark 1 to do with the fuse box location and I will have to make a relay off the battery? Not too sure how to go about this, can anyone advise?
    20v kit car Guest
    first check the earth station for the headlight...many mk1's have this as a common prob located on the chassis rail..upgrade the globes to QI if not already. cheers steve
    syncro Guest
    Try cleaning the fuses.
    They really benefit from a relay upgrade.
    What year model is it?
    imported_brackie Guest
    Me too!
    Yeah, mine are about 1 candlepower (and the motor is 1 ratpower). Please give us a checklist of things to look at.
    syncro Guest
    Ignition switch.
    I think that I may have write some instructions for an upgrade for you all.
    Allens Rivulet, Tasmania
    please do mate, please do, i hate it, mine are dull as
    Camden, Sydney
    EARTH CONNECTION
    Clean em up, the ones by the headlights and the one behind the dash instruments, go up from underneath, particularly if there has been water in through the windscreen or firewall.
    Then a relay. Yeah syncro, let see a diagram.
    Quote Originally Posted by syncro
    Ignition switch.
    We're still waiting! (Some of us may not survive our next encounter with a log truck on a dark country road!)
    Looney...Could you be specific about the under-dash earth point? I took the connector off the back of my headlights and direct-earthed the circuit in parallel with the existing earth. Made no difference.
    Surrey, UK
    I put a HID conversion in mine, driving in the dark is like daylight now. A bit expensive though.
    syncro Guest
    Quote Originally Posted by brackie
    Ignition switch.
    I'm working on it.
    Which model should I start with? '76?
Similar Threads
  1. 8v head build up
    By static1800 in forum Mk2 Golf & Jetta
    Last Post: 05-03-2007, 09:16 AM
  2. Help - Brake lights dont work!
    By XXX-1.8T in forum Mk1 Golf
    Last Post: 24-09-2006, 12:11 AM
  3. Head gaskets and rings
    By hiho in forum Diesels
    Last Post: 05-05-2006, 07:04 AM
