Results 1 to 10 of 17
Thread: head gasket gooone! what to do next?
    Jan 2009
    south west sydney
    So i'm 90% sure i've done a head gasket in my stock 1.6. had 250,000km on the clock but the clock has been stopped for as long as i've owned it so who knows how far it's beenn. I haven't exactly given it an easy life.
    So what next? if i'm pulling the head off should i be looking at a full rebuild? privided it's the gasket that's gone and not the block or head. is it worth it? maybe a cam and some head work?
    or should i bin the 1.6 and move on to something else. would love a 16v but not sure it's in my budget at the moment.
    what would you do? If you know how much your idea would cost include that too as i'm still pretty noobish with what mk1 conversions are out there.
    Oakleigh VIC
    Plonk a MK3 / Cordoba 1800 in it. Around $500 and the best bang for buck going. Easy bolt in conversion.
    Chat to Matt at Camden GTI for all the bit or check out the for sale section.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Jun 2007
    Eastern Suburbs Melbourne
    bolting a 1.8 from a mk 3 in is an easy way to update to a fresher, more powerful engine; without having to spend much money. Then spending a bit of money on pwerformance stuff will get some nice results (as opposed to throwing a cam in an old ass 1.6)
    If you're keen to just get the car running again, whip off the head, take it (and the gasket) down to your local engineering/head work shop and get them to look at it. You might be lucky, it could just be the gasket. Get the head washed and faced (should be around 70-100bucks) slap a new HG on and whack the head back on. You'll probably want to replace the valve stem seals too. None of this is particularily complex, how ever it does require a bit of know how, and a bit of patience.
    You could do all that, however for only a touch more ($$$ and effort) , you could pop a 1.8 8V in, and never look back. As Pete mentioned, talk to Matt, he should be able to sort you out.
    hth.
    i like volkswagens
    Jan 2009
    south west sydney
    $500 sounds alright. is it still a carby engine? or does that conversion require engine managment?
    Jan 2008
    Strathfield,Sydney
    Quote Originally Posted by MiKe1_golf View Post
    hey mate i went the 1.8 route but also gotta mk1 gti short ratio box put in ($600). Could stick with the 4 speed no worries but i just thought i might as well seeing as i was swapping to the 1.8.
    its a carby engine so you can actually keep the mechanical fuel pump but i swapped to the electric fuel pump which is quite easy also.
    whack on a 32/36 webber downdraft like ive got and hold on! good fun revs like a demon!
    76 Scirocco
    Sep 2009
    Chillaxing in Tas
    Quote Originally Posted by dom123 View Post
    What pump do you run?
    <space for rent>
    Is the MK3 1.8 good for 90hp?
    Oakleigh VIC
    Yep, in stock form. 90 PS (66 kW; 89 hp) @5500 rpm 145 N·m (107 lb·ft) @2500 rpm
    7? MK1 Caddy
    12 Amarok
    Jan 2009
    south west sydney
    how do you run an electric fuel pump with out an ecu? just hooked to ignition and always on?
    Jul 2010
    Robina Gold Coast
    Camden GTi have a heap of engines that would fit your car, and they can install it , give the Golf loon a call .
