Results 11 to 20 of 23
Thread: head 8v?
    May 2006
    Maryborough Vic
    well before it stoped it was a bored and balanced 1.6 with big manly
    valves 40.5 & 36 and ported and cam was scatt c 35 grind with weber
    but head was bent and had cracks under 5 valve seats and had washed
    the bore aswell . so i went to doner car 77 bored and deck block
    and machined crank and balanced cause other was wornin thrust.
    cam was pitted had reground. but spare head was a banana and they
    broke it trying to get it straight , big spanner in works. so i have big valves and cam but no head for them.
    imported_brackie Guest
    Welcome!
    Welcome mate! Looks a good Golf in the making. C'mon, you guys.... surely someone has a spare head lying around Help this guy out!
    Apr 2006
    Hobart,Tas
    I have a couple of heads lying around but might need overhauling. Surely there are heaps in vic tho. Wait till the "swallowtailers" see your Golf today, you shoud get some responses! If no-one has a head over there let me know. Cheers!
    May 2006
    Maryborough Vic
    another thing it needs clutch upgrade aswell smoked standard one
    any sugestions thanks for the reply's
    Camden, Sydney
    Ive got a couple of 1.6 heads lying around. Not big bucks.
    And some GTI clutches. PM me or 0423 051737. Freight no worries.
    May 2006
    Maryborough Vic
    thanks to golfwise for help with the head
    how big is a gti clutch 200mm 210mm and
    how tuff are they cause im a cruell master :twisted:
    i got a factory workshop manual but it doesnt have spec's
    that for the help guy's.
    Camden, Sydney
    170mm Stock clutch, 190mm GTI, 210mm 16v
    I think. Some pedant will correct me if I`m wrong.
    Golfwise Guest
    I'll be it then
    1.6 is 190
    1.8 2.0 is 210 be it 8 or 16 valve
    Stop guessing Loon.
    I've never seen a 170 ??????
    must change my user name to " PEDANT "
    May 2006
    Maryborough Vic
    i was told to ge a button clutch made but drove a
    customers supra with one in it and it was crap just like
    the rest of the car
    Dec 2005
    Button clutches suck for everyday use. Mate has a r32 gtr with a triple plate and its sucks! stalls all the time, unless you take off at 6000rpm, then u just leave black lines everywhere!
Similar Threads
  1. 8v head build up
    By static1800 in forum Mk2 Golf & Jetta
    Last Post: 05-03-2007, 09:16 AM
  2. Head gaskets and rings
    By hiho in forum Diesels
    Last Post: 05-05-2006, 07:04 AM
  3. VR6 head gasket problems?
    By worm in forum Mk3 Golf & Vento
    Last Post: 26-04-2006, 12:51 PM
  4. 16v engines for mk1.... (subject now)...head refitting
    By finemk1 in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 12-12-2005, 03:38 PM
