Results 11 to 20 of 21
Thread: Hard braking causes car to force stall
    Sep 2011
    coolangatta
    Quote Originally Posted by kaanage View Post
    of course you have to be aware that you will need to press on the brake pedal a LOT harder to slow/stop the car when testing this.
    you can just test it on stationary.
    1976 VW Golf LS 4Door 1600cc
    Oct 2010
    Melbourne, VIC
    Resident grumpy old fart
    Apr 2009
    So when doing this what should I look out for?
    -'75 Passat TS
    -'75 Passat TS (Project)
    No....its not a Piss-sat its a Pass-sat!!
    Oct 2010
    Melbourne, VIC
    chesymoon is pointing out that the leaky booster should have an effect on the car when it's just idling if you stamp on the brakes so you could disconnect and plug the vacuum line and stamp on the brakes to see if the car just idles with no change.
    Apr 2009
    OK so I pulled the vacuum line end where it connect to the manifold, plugged it up, tried to start the car and the car could barely idle.
    Then I unplugged it and connected it up again and the car started normally.
    Thoughts??
    -'75 Passat TS
    Jul 2005
    Newcastle, NSW
    You need to remove it from the brake booster and plug that end as you need the manifold bit connected for other vac lines.
    I just removed a working one from my mk1 if you are looking to buy a different one, I upgraded to a larger diameter one.
    Apr 2009
    Ooooohh I see what you mean mik, I had the wrong one plugged. And thanks for the offer but I've basically got the same setup as you and I prefer to use the larger diameter booster as well.
    So I plugged the manifold bit as suggested above, as expected the brakes were harder to step on but it made no difference to idling if I was stepping on the brakes or not. (I tested this stationary, not moving)
    I should make this clear, the car only cuts out when stomping on the brakes when Im driving, when stationary I can stomp all day long. But when stationary and I stomp on the brakes quickly the engine stutters a tiny bit.
    Also when driving and I stomp on the brakes I noticed if I stomp hard, then release then stomp again, the engine just survives. So when I feed the brakes once or twice the engine stays alive.
    If im blabbering on like an idiot and not making sense just tell me
    -'75 Passat TS
    Aug 2008
    SYDNEY
    Its not a booster issue.
    If you are running a 32/36 weber, than what you are experiencing is fuel surge in the bowl. I had this as well, used to surge when turning right and decelerating and as a result it would stall. Its because the 32/36 weber wasn't designed to run on a transverse engine.
    There is no real way around it, as I had mine professionally tuned and it still did it. Had to change my driving style (keep it in gear longer). got used to it after a while.
    2008 POLO GTI - SOLD
    2005 MkV Golf GTI - couldn't resist
    Mar 2008
    Wollongong, NSW
    2nd the last post. i had a 32/36 and surge caused it to stall on hard braking. the guy who tuned it up for me said it might be a problem as the way it was mounted (transverse) was not what they were designed for, or something or rather. i had to change my driving style.
    '11 Golf GTI - Tornado Red, 5dr, DSG, 18" Detroit's, ACC, Sunroof, Park Assist, RVC, Tint, Leather, Electronic Seat
    previously: '00 audi a4 turbo quattro avant, '89 audi 90quattro20v, '78 golf 1.8l
    Apr 2009
    Im starting to think this as well, since I performed a few tests on my brake booster and it didnt seem faulty.
    -'75 Passat TS
